XJS '94 Manual!- when it's gone it's gone!!
Get it quick!! OMG - this is cheap but sounds genuine; too good to be true? Got to be worth a look being a factory manual. I have one so am slightly miffed is so cheap! https://www.ebay.co.uk/itm/JAGUAR-XJS-4 ... 3514764119
Re: XJS '94 Manual!- when it's gone it's gone!!
Hello greenban,
How do you know it's cheap when it still has 2 days of the auction to go and the reserve has not been met.
Looks quite nice in the photo's.
MOT history show repairs have been carried out but you never know the quality of the work
Take care.
Take care.
Date tested 20 November 2018
Pass
Mileage 87,160 miles
MOT test number 5225 4119 2726
Test location
View test location
Expiry date 19 November 2019
Monitor and repair if necessary (advisories):
Front Coil spring corroded both sides (5.3.1 (b) (i))
Rear Coil spring corroded both sides (5.3.1 (b) (i))
Front Wheel bearing has slight play both sides (5.1.3 (a) (i))
exhaust system corroded
Offside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
fuel pipe corroded
Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement both sides (5.3.4 (a) (i))
What are advisories?
Date tested 13 November 2018
Fail
Mileage 87,147 miles
MOT test number 4993 5154 8301
Test location
View test location
Do not drive until repaired (dangerous defects):
Parking brake efficiency less than 50% of the required value (1.4.2 (a) (ii))
Repair immediately (major defects):
Offside Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 (c) (i))
Offside Rear Suspension arm pin or bush excessively worn trailing arm (5.3.4 (a) (i))
Windscreen washer not working (3.5 (a))
Front Anti-roll bar corroded but not seriously weakened (5.3.3 (b) (i))
Nearside Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Offside Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Nearside Front Coil spring corroded (5.3.1 (b) (i))
Offside Front Coil spring corroded (5.3.1 (b) (i))
Offside Rear Coil spring corroded both springs (5.3.1 (b) (i))
Nearside Rear Coil spring corroded both springs (5.3.1 (b) (i))
Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Fuel Pipe/s corroded ()
Oil leak, but not excessive (8.4.1 (a) (i))
Offside Door hinge worn
Offside Rear tyre cracking
Pass
Test location
View test location
fuel pipe corroded
Fail
Test location
View test location
Ouch - good spot! Needs some work then!
