Front side light
Moderators:robv12, DavidEm
DougX
Front side light
Postby DougX » Tue Nov 27, 2018 3:26 pm
I am trying to replace the front side lights. I have taken the main headlight electrical connector off so that I can get to the little side light connector. Tried twisting and pulling but it won’t budge. Can anyone advise how this should be removed?
Andy P
Re: Front side light
Postby Andy P » Wed Nov 28, 2018 2:10 pm
Hi DougX,
Rotate the bulb holder anti-clockwise 1/4 turn and pull out of the Headlight unit.
Side Light
Jaguar Parking Lamp bulb removal.jpg (9.79KiB)Viewed 2076 times
If you're having problems getting the lamp holder out of the light, try some release agent after a drive when the plastic is warm and a pair of long nosed pliers to wiggle the holder out.
Hope that helps Doug.
Good Luck.
Andy :D
DougX
Postby DougX » Wed Nov 28, 2018 2:17 pm
Thanks Andy, will give it a try and will let you know if I am successful.
DougX
Postby DougX » Wed Nov 28, 2018 4:16 pm
Brilliant. Although hard work turning them, the space is very confined, I managed to get both out. Couldn’t have done it without your knowledge Andy. Many thanks again. :)
