Front suspension rebuild/re-weld ?
Jaguar5993
Postby Jaguar5993 » Wed Nov 07, 2018 11:45 pm
Hi,My 95N XJS 6.0 needs a front suspension,DIY recondition,together with all the other parts under my car.
I really want to go for the complete renew/sandblast and paint look.
However,I have noticed that the downward facing spring guide cups have rusted and in fact ,trapped and fallen down inside the spring and resting on the base plate.
These were originally spot welded to the main unit and the hole in the cup,I guess is where the correct spring compressor goes through.
I am worried that if I buy one of those £300-£500 xjs/xj6 units on eBay,they might or soon to go,the same way.
Does anyone know if I can you buy just these front spring cups,for me to re-weld on?
Obviously,when things are concerned near to those deadly springs,I have to be sure the welding is up to scratch.
Any thoughts?
Thank you
Nick W.
1995 XJS 6.0 V12 Coupe
Re: Front suspension rebuild/re-weld ?
Postby davidr » Thu Nov 08, 2018 8:35 am
Hi Nick - that's the weak spot of those units. Throw that one away. It's scrap. Trying to repair it would not be recommended. It sounds like it may have been "repaired" in the past and has failed again?
You will need to find another one but I would strongly recommend that you do not buy one that you haven't personally inspected.
Jaguar5993
Postby Jaguar5993 » Thu Nov 08, 2018 9:30 am
Thanks David,
I am leaning more towards another one and yes...it makes sense to inspect one first, locally.
It’s a big piece of kit,so that’s probably why they are averaging out at £500 (often looking rusty).
The main part of mine is in good condition,so I was hoping for about £80,just to replace these cups myself.
My bolts also,holding the spring base plate on to lower wishbones will shear off,so might be better to try with another unit and rebuild at leisure.
I have had this car since 2001,so pretty certain it’s not been welded,but it had an early hard life running down the salty sea roads of the east coast of Scotland (Inverness) to London,so that might of added the rusting?
Thanks again for your advice.
Nick W.
