Upper column bearings
Mgcjag
Postby Mgcjag » Tue Nov 06, 2018 5:53 pm
Hi All..S2 xj6.. upper steering column has 2 tapered roller bearings....they have a plastic cage which is unusual.....they need replaceing..any one done this.....where can i get the bearings...the usual suppliers dont have them.....thanks...Steve
Steve.. 1969 S2 2+2 E type..Daimler Sovereign S1 1971
Re: Upper column bearings
Postby mike020150 » Wed Nov 07, 2018 12:28 pm
I don't recall Jaguar ever supplying taper roller bearings for the column, just the plain upper bushes so I suspect you will have to find an equivalent bearing via a friendly bearing factor. Mike.
Tintin
Postby Tintin » Wed Nov 07, 2018 12:43 pm
I suspect you are referring to the taper roller bearings that are part of the collapsible steering column assembly; these bearings position the inner shaft in the outer column. Being part of a safety critical assembly they were never available separately only as part of the column. I suspect your only hope is a salvage yard.
Robbie
Daimler Sovereign S1 4.2 1971
Mgcjag
Postby Mgcjag » Wed Nov 07, 2018 4:18 pm
Hi...yes its the taper roller bearings.....the column is simple to dismantle just a tiny circlip to remove at the bottom then it all comes apart.....yes a breakers is a route i could take.....anyone out there dismantled theirs for a refurb and managed to find a supplier..thanks.... Steve
