XJ8 X308 Throttle Body C2A1470
Moderators:robv12, DavidEm
RichardSEL
Postby RichardSEL » Mon Oct 08, 2018 7:46 am
Used OEM Throttle Body tested & working taken from 2001 XJ8 3.2L
That car has terminal underfloor rust so was parted out. Engine ran
fine with this throttle body in place
£148 +£6.95 p&p
also at: https://www.ebay.co.uk/itm/Jaguar-XJ8-X ... 3473931458
This part superceeds the following part number(s): LCA1560AG, LCA1560AJ, LCC1560AA and LCC1560AA1
Fits: XJ8 3.2L 2001 (bought for mine but found not needed -- I had intermittent fuel pump fault),
X100 XK8 coupe/convertible (4.0L V8 models) VIN range: from start of range to 042775 -- not supercharged models
and
X308 (4.0L models) VIN range: from 812317 to F59525 -- not supercharged models
Recommend you get fresh gasket
RichardSEL
Re: XJ8 X308 Throttle Body C2A1470
Postby RichardSEL » Sat Nov 24, 2018 6:21 pm
SOLD
