Does anyone know when the 400 sport production run started and ended ?
400 sport info
Re: 400 sport info
Since Jaguar has a tendency not to separate model variants by having a specific VIN marker, this type of question is always difficult to answer without access to the factory records. You will probably have to wait until someone writes the definitive F-Type story and does the necessary detailed research before you can find the correct answer. Mike.
Re: 400 sport info
ThanksSince Jaguar has a tendency not to separate model variants by having a specific VIN marker, this type of question is always difficult to answer without access to the factory records. You will probably have to wait until someone writes the definitive F-Type story and does the necessary detailed research before you can find the correct answer. Mike.
ianoliver57
Re: 400 sport info
As far as I know, the Sport 400 was a limited edition run to be available only during 2018. Don’t know how accurate that is, but that’s what I was told by main dealers in Glasgow.
Regards. Ian.
Regards. Ian.
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
2021 XE R Dynamic P250 S
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
