X150 wiper replacement
andypryce
Postby andypryce » Sun Aug 12, 2018 5:17 pm
Hi all,
Does anyone know how to replace the wiper blades on the x150? They only tilt by 10 degrees which would seem to make removal impossible?
XF Sportbrake 2020 / XK8 1998
Astromorg
Re: X150 wiper replacement
Postby Astromorg » Sun Aug 12, 2018 8:06 pm
I hoped to attach a copy of the Jaguar W'shop manual instructions, but it would seem that pdf and Word docs can't be used!
So to try and explain! Remove the air inlet cover around the right hand wiper spindle. There are three clips holding it, two inboard and one outboard.
Remove the blanking plug on the wiper arm spindle and undo the nut below it.
Disconnect the washer jet block from the cowl vent screen.
Remove the wiper arm assembly after which you should be able to unclip the oldwiper blade from the arm and fit the new.
Refit the arm assembly, using the alignment mark on the windscreen to position it correctly.
Lefthand side should be similar.
It would seem that aerodynamic requirements have overtaken the old fashioned way!!
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
andypryce
Postby andypryce » Sun Aug 12, 2018 9:03 pm
Great, many thanks.
andypryce
Postby andypryce » Tue Sep 04, 2018 10:23 pm
All done, thanks again.
