Can anyone confirm if these are exactly the same parts? The first is the front door waist seal for the X308 and the second is the same part for the X300. In simple terms are the doors in these cars exactly the same?
thanks
Ewen
GNA1710BF or GNA1710BE
PeterDavisX300
Re: GNA1710BF or GNA1710BE
Hi Ewan
I have replaced all four waist seals on my 1995 X300.
Front door near-side bright finish = GNA1711AE I paid £65, I believe there is no longer stock at that price and they're about £95
Front door off-side bright finish = GNA1710AE I paid £65, I now believe they are about £155
Rear door Near side bright finish = GNA2521AE I paid £95, I think they are still that price.
Rear door off-side bright finish = GNA2520AE I paid £285, a real killer, but the local garage felt sorry for me and took 25% off.
The X308 has the same finishers. Tricky to fit, especially the front with having to remove the door card and mirror, be careful, if you make a mistake it will be expensive. Allow 2 hrs for each front door carefully fitted, allow half an hour for the rears.
Peter
Peter
1984 Mercedes 450SL Rag-Top
ewenmacaulay
Thanks Peter so if I purchase the X300 waist seal it will fit the X308 front door?
Ewen
Ewen
PeterDavisX300
Hi Ewan
Same part number, but you can check here. https://www.jaguarclassicparts.com/uk
Look up the part for the 308 and the 300, same part number.
Peter
Peter
