convertible roof hydraulics
purley
Postby purley » Tue Aug 07, 2018 12:21 pm
Hydraulic fluid has just started seeping through the header rail in my 1997 XK8. What could be the problem please and how can I fix it.
Many thanks. Malcolm.
Re: convertible roof hydraulics
Postby mike020150 » Wed Aug 08, 2018 10:02 am
Your car could have a broken pipe/leaking joint or a faulty hood latch cylinder. Stripping it to check is the only way you will determine the precise problem. Originally, your car will have had a type of hood fluid later abandoned by Jaguar because it had a tendency to gel and slow/stop hood operations. Consequently, if not already done, any work in this area should include flushing and changing the hood fluid to the later Pentosin specification. Mike.
Foffer
Postby Foffer » Wed Aug 08, 2018 1:09 pm
Hi Malcolm
I had the same on my 2001 XKR last year, although mine was a larger quantity than you describe! I was told that one of the pair of hydraulic hoses that operate the claw above the rear view mirror had split/burst due to age, having perished and it was necessary to replace both hoses which go all the way from the hydraulic pack in the rear to the claw device. This meant removal of a large amount of the interior and the total cost was about £800. Sorry if that's bad news!
Current cars: 2014 XF 2.2 200 Sportbrake and 2001 XKR 4.0 Convertible
Past Jaguars: XJS 5.3 Coupe (pre-HE) and Mk2 3.8
JimboV8
Postby JimboV8 » Wed Aug 08, 2018 2:23 pm
This is the guy you need to talk to. memberlist.php?mode=viewprofile&u=12009
He’s done everything himself with pictures. :mrgreen:
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
purley
Postby purley » Thu Aug 16, 2018 5:23 pm
Thanks for your replies. I have been lucky so far in that nipping up the connections seems to have done the trick!!
Why hydraulics; electric would have been easier! Thanks again; an interesting exercise.
