Water pump
Moderator:cawthrm
venge
Water pump
Postby venge » Sun Apr 15, 2018 3:10 pm
Does anyone know where the water pump is located on my diesel XF 2.7 V6. I have had a problem with loosing coolant but the seal stuff you put in the water tank has not worked. I noticed today that there was steam coming from something on top of the engine and the large pipe coming from it was cold and felt empty. Was wondering if this might be the water pump. If so, are the easy to replace?
Any help you guys can offer would be greatly appreciated
2004 X350 3.0 V6
