blower switch fault
CliveRothwell
blower switch fault
Postby CliveRothwell » Sun Apr 08, 2018 10:40 pm
1991 4.0 facelift
It seems that it won't turn off even with the key out of the ignition! Any thoughts please?
Re: blower switch fault
Postby davidr » Mon Apr 09, 2018 8:46 am
I assume that it's just one side that's affected? If so, it's probably the electronic board on top of the blower motor that is causing the issue. Your only choice in the short term is to pull the fuse.
You will need to take the blower motor out to assess the board on top.
There are plenty of threads on here about the issue.
David
CliveRothwell
Postby CliveRothwell » Mon Apr 09, 2018 12:15 pm
Thanks - I'll have a look.
poprivet
Postby poprivet » Mon Apr 09, 2018 1:35 pm
If it's blowing hard the relay could be stuck on, just a gentle breeze and it's the transistor as David suggested. Check each side from under the scuttle.
I don't thin the facelift changed much from the earlier Delanair 3.
http://www.jag-lovers.org/xj-s/book/acblower.htm
CliveRothwell
Postby CliveRothwell » Mon Apr 09, 2018 8:04 pm
Hmmm pity! That all sounds a bit complicated. It's unfortunate as I've only recently finished replacing both blower motors on my
XJ6 series 3............and what a performance that was!
Thanks Pop. I'll wait for the weather to improve...............
Postby davidr » Mon Apr 09, 2018 8:16 pm
Oh well. At least you know how to get them out! XJ very similar to XJS. Always easier second time! :D
