Front Suspension Interchangeability?
Gilly70
Postby Gilly70 » Fri Mar 30, 2018 7:50 am
Hi, I'm new to the group so apologies if this question has already been asked.
I have a '89 XJS 3.6 that needs the front suspension crossmember replaced due to corrosion. Are the crossmembers interchangeable between all XJS models? Thanks in advance for any advice.
Re: Front Suspension Interchangeability?
Postby davidr » Fri Mar 30, 2018 9:28 am
The front cross member is the same in all XJ-S and XJ Series 1-3 models. Be careful when buying to make sure there is no structural corrosion. It may be best to find one from a V12 as they tend to leak more oil! The area to pay special attention to is the spring tower (but I guess you've already found that out!) and also make sure that the fulcrum shafts (especially the bottom one) can all be removed without damage as they rust in place.
