cold when steering left
JagmanXJR03
Postby JagmanXJR03 » Fri Mar 09, 2018 8:29 pm
Hello all.
A weird one, when I steer left, the inside of the car gives me a cold blast whilst driving even with the windows up and vents shut, but on normal driving and turning right, all is perfect. Has anyone else had this?
Present 2004 XJ6 Sovereign with all bells and whistles
Past:
2004 X Type SE 2.5 Estate
2007 S Type 2.7D SE
2003 S Type 3.0SE
2003 X-Type 2.5SE
Montana5
Re: cold when steering left
Postby Montana5 » Sat Mar 10, 2018 2:40 pm
Strange one indeed, however as there are three common faults with the S Type HVAC...
Heater Valve, Climate Control Module and broken or corroded Wiring Loom.
I would hazard a guess that there may be an issue with your Wiring Loom, could even be inside the Car at Steering Column.
Doug.
S Type Forum Moderator
