Brake - Warning Light Query
Milan
Postby Milan » Sat Jan 12, 2008 2:58 pm
The yellow ABS and red exclamation mark lights comes on at ignition then go out after a few seconds on my 89 XJ-S. The lights do not come on at any other time. Any suggestions as to to what might be causing this? The brake fluid level is above max, so I assume that's not the issue.
Postby ptjs1 » Sat Jan 12, 2008 5:38 pm
Milan,
Isn't that what they are supposed to do? I'm not too sure about '89 models but all cars that I know with ABS will illuminate the ABS & brake check lights on at ignition start up and then the lights will go out after a pre-determined time or when the car reaches, say, 8 mph. If you check your handbook, I suspect you'll find that your car is behaving as per normal.
jbb1994
Postby jbb1994 » Mon Jul 21, 2008 9:12 pm
Yep Paul`s correct. If either don`t come on & stay on for a small time at start up, or stay on all the time you`ve got problems.
88 3.6 & 95 4.0 Celebration Coupe
