Hello Folks,
In the process of removing the downpipe from the manifolds on my XJ6 X300 3.2 and unsure of where the connector blocks are for the 2 Lambda sensors. I have seen 2 connector blocks located directly behind the cylinder head but unsure if these are the correct ones as the wiring looks different. Would appreciate any guidance. Thanx in anticipation..Charlie.
XJ6 X300 3.2 Exhaust downpipe Lambda sensor connector locations.
xjscharlie
Re: XJ6 X300 3.2 Exhaust downpipe Lambda sensor connector locations.
Hi Charlie.
Those 2 connectors between the bulkhead and the rear of the cylinder block are the ones for the lambda sensors.
Tricky to get to but do-able.
I trimmed back the protective wiring covering and moved mine a little to the right (sitting in the car) to make it easier - if there was to be a 'next time'.
2003 X350 XJR - daily driver
Past vehicles:
Past vehicles:
xjscharlie
Many thanx~its good to know that one is not barking up the wrong tree..Rgds.
