Windows
jaysto
Windows
Postby jaysto » Wed Feb 07, 2018 2:57 am
Drivers door window dropping and lifting even when door is closed.drivers door open message on dash when door is closed?? Reset windows but always goes up fully when I open door,so can’t close door without lifting the handle to make the window drop .hard to start in cold ,had battery check and was ok ,alternator or belt fault ????
Re: Windows
Postby mike020150 » Wed Feb 07, 2018 11:18 am
What you describe may consist of more than one fault. Despite having had a battery check, my suspicions would lead me to beg, borrow or buy another new battery before going any further. XKs are incredibly voltage sensitive and even a battery which is easily capable of starting the car may generate false warning lights and other issues. Mike.
JimboV8
Re: Windows
Postby JimboV8 » Wed Feb 07, 2018 9:17 pm
Fully agree with Mike, get a fully charged battery fitted first and then reset the window memory. If you still get the open door message then that would point to a failing “door ajar switch” situated in the door lock mechanism.
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
Users browsing this forum: No registered users and 14 guests
