Fancy a five speed 'box?
Moderator:shugmcd
RoyC
Postby RoyC » Thu Sep 07, 2017 7:35 am
"The JD Sport five-speed transmission has been designed in-house for the classic Jaguar range, or other marques that use similar transmissions. With a power rating of 400bhp, it will be equally at home on either the road or track in a Jaguar E-type or Mk2, and any Jaguar XK. Dimensionally the same as a 4.2 all-synchromesh unit, the JD Sport five-speed transmission is actually lighter than any period factory unit. It uses a reinforced aluminium casting, and all-synchromesh helical cut gears."
http://www.jdclassics.com/news/2017/JD- ... s/4361.htm
Video: https://www.youtube.com/watch?v=uY-Ht-ENaS0
Roy
Suffolk Jaguar SS100
lowebird
Re: Fancy a five speed 'box?
Postby lowebird » Sat Sep 09, 2017 8:05 pm
Roy,
Have you any idea of the comparative costs with the Tremec 5 box?
RoyC
Postby RoyC » Sun Sep 10, 2017 6:51 am
Reg,
POA, but I imagine that, with the amount of design work that has gone into its' construction plus the JD Classics name, it will be quite an expensive item.
Roy
Roy
