Radius arms large bushing
poprivet
Postby poprivet » Fri Aug 18, 2017 3:44 pm
I noticed the bonding between the rubber and steel is seperating.
I took off the safety strap and had a good old prod about, the rubber is parting both on the inside and outside of the bush but it is secure and no amount of heaving about would make it come off so I'm sure that it's not about to fail catastrophically. The steel arms are in good nick and the small bushings look fine so do I replace the large ones or leave them for a while?
Not a major job to do but one I would put off if not immediately necessary, that do you think :?:
Re: Radius arms large bushing
Postby davidr » Fri Aug 18, 2017 5:40 pm
It's an MOT fail so my advice would be to do it asap
poprivet
Postby poprivet » Sat Aug 19, 2017 3:38 pm
MOT passed only 450 miles ago with no advisaries but I take your point.
I took one side off today, without any problems. I'm pleased that I used copperslip on the mounts and bolts in November 1999 when I last replaced them. Back then the whole arm had rotted through and the rubber was hanging off in a way that reminded me of a pair of slippers of mine that our dog of the time, Toby the Jack Russell, had given a good seeing to. Back then I bought new arms complete with Metalastic bushes already fitted.
On the workbench, it could be seen that both large and small bushes are starting to fail so it is timely to replace them all. The internal waxoyl and outside underseal that I used at the time has done a good job of keeping the steel arms in good order, so as long as the bushes press out without drama will be good for many years to come.
Next questions: Metalastic, pattern or neoprene bushes? Holes in large bush in-line with the arm or across it? :|
Postby davidr » Sat Aug 19, 2017 4:29 pm
My advice would be Metalastic for the large bushes and polybush for the small one.
I have my own with the holes in the large bush in line with the radius arm as this gives extra compliance. If you want to firm it up then put the holes across.
PaulGover
Postby PaulGover » Mon Aug 21, 2017 12:32 pm
Somewhere in the depths of Roger Bywater's AJ6 Engineering website there's an interesting comment on how the movement permitted by the standard fitment improves handling (as well as ride); perhaps all the racing types with bushes turned through 90 degrees are fooling themselves.
For amusement, I took my radius arms to my local Jaguar agent (mine also are separating). They said they couldn't do it, as they no longer have the necessary tools, and would end up grinding the old bush out. I'm going to see if I can convert a spare trolley jack into a press (probably before deciding that's not worth the candle and taking the arms to a local garage with proper tools).
poprivet
Postby poprivet » Mon Aug 21, 2017 8:52 pm
I had an interesting time removing the bushes. I hadn't realised that the large bush housing has a lip on the top surface so the bush has to come out in only one direction. the problem is that so little metal is left showing of the bush outer ring I couln't find anything suitable to use as a drift.
Very cafeful grinding was needed to release it without scoring the carrier in any way. On the bench it was obvious that the small bushings needed replacement as well, the old trick of using a couple of sockets might have worked if I could have found any that fitted, after turning the workshp upside down I gave up and ground that out as well.
It would have been easier to buy new arms with bushes already installed even though I have access to a good hydraulic press!
I'm awaiting parts now but at least the new ones should go in easy enough, if I remember to take the camera to work I will take a photo of the press in action.
poprivet
Postby poprivet » Thu Nov 02, 2017 1:42 pm
I forgot to follow up this thread.
No photos but the bushes were all installed easily and the arms given plenty of waxoyl inside and out before re-installing.
No difference in handling as I would have expected as the splits were noticed before failing. Good preventative maintenance.
