First post to the forum so be gentle as I’m not sure if this should be engine, electrical or ignition.
Let’s start with some history:
The car is a 4.0 Celebration with an LPG conversion and although the problems I'm having are much worse when running on gas the car has the same symptoms running on petrol although much less frequently. Oh and it did occasionally happen before the LPG conversion.
The problems:
When started from cold (running on petrol) the car does not accelerate, it is not misfiring at this point there is just no urgency when you put your foot down.
After the switch over to LPG the misfire starts, it is not continuous I can drive for miles at varying speeds without a hiccup and then for no apparent reason it starts missing.
Now for the weird bit when the engine starts to misfire about 25% of the time I get the following warning lights... screen wash, seat belt, handbrake and I think the ABS/Brake warning. This can happen at any time; stationary or cruising on the motorway, but is a lot more frequent at low speeds. If the seat belt is not done up the seat belt warning alarm will sound.
What’s been done so far:
I’ve had a Jaguar specialist look at it and he couldn’t find out what was wrong.
I then tried a very good local garage who first thought it was a wiring problem in the passenger footwell; it wasn’t. But after a chat with Webbers Jaguar in Basingstoke he was told to try changing the NGK plugs to Champions, this fixed the problem for about 2 weeks. But the problem has appeared again and has gradually got worse.
Has anyone got any ideas?
Could it be coils? Ecu? Lambda sensor?
Help!
Thanks in advance for any help.
Rod
4.0 Celebration misfire and warning lights
Rod,
Welcome to the Bulletin Board! don't worry, I'm sure everyone will be very gentle with you! I'm sure there are others far more technically knowledgeable than me, but for what it's worth I'll give you my thoughts.
The symptoms on the car seem quite confusing, so you probably need to take quite a logical structured approach to working out the problem.
It's always going to be more difficult to work out the problem when you've got the dual-fuel issue which may well be a bit of a red herring.
Looking at it logically, if the problem was there before the conversion, then it would imply that the LPG is not the issue. However, there are two main reasons why such a problem might appear worse when running under LPG. LPG has a significantly higher octane rating than petrol, about 112, and therefore, to operate efficiently really needs a greater degree of ignition advance. The second thing is that LPG really needs a very strong ignition systemm to work well. Many LPG users use magnecor plug leads and more powerful coils (on conventional ignition systems). Any weakness in the ignition system will show up worse when running on LPG. One good thing about having the problem with LPG is that you know it's not fuel pump or fuel injector related.
The link to the ignition lights might provide a clue to the problem. It almost seems as if the ignition has momentarily cut out at that point, which causes the lights to come on. (At that point, the oil pressure would still be sufficient for the oil light not to come on)
Because the coils are individual, I don't think that can be the problem. Also, in my experience, lambda sensor failure doesn't really cause misfiring, it just seems to mess up the emissions.
So perhaps it's an ECU issue? Maybe a dry joint or loose connection. You could try disconnecting it and cleaning up the connections to start with.
I would suggest you give David Marks a ring and ask his advice. Don't labour the LPG point, though, just mention that it's worse when running under LPG.
Good luck, Rod, let us know how it progresses.
