fixings for S1 headlamp nacelle/scoop
Moderators:iRS, Art1012
Rob.Brinkworth
Postby Rob.Brinkworth » Sun Jul 09, 2017 1:25 pm
Can anyone help with the correct spec and/or part numbers for the screws/nuts/washers that attach the headlamp nacelles to the bonnet on a S1 3.8 please? The previous owner who restored the car used 1 inch lengths of sawn-off 2BA (I think) studding and nuts as required. Now that I've gone to the trouble of restoring the nacelles to the correct colour, I may as well use the correct fixings to fit them! I looked at the SNG Barratt catalogue but I can't see them listed. My understanding is that screws should be fitted from inside the bonnet area, through the captive nuts on the nacelle and locked by further nuts once the nacelles are correctly aligned. However, I don't know what to buy. I'm guessing stainless steel would be the best material. Any advice welcome!
Regards, Rob.
Rob.
1964 E-Type 3.8 FHC
1977 Daimler Double-Six Coupe
2000 XJ8 Executive (now sold)
1969 Mini Cooper
1973 Austin 1300GT
2013 MINI John Cooper Works
stuarthardy
Re: fixings for S1 headlamp nacelle/scoop
Postby stuarthardy » Sun Jul 09, 2017 7:49 pm
Hi Rob
You need 2 off 3/16" UNF x 3/4" hex head set screws and 4 off 3/16" UNF x 1" hex head set screws. You also need 6 off 3/16" spring washers, plain washers and (UNF) nuts, of course.
The spares book also says use distance pieces C1094. Quantity as required.
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
Rob.Brinkworth
Postby Rob.Brinkworth » Mon Jul 10, 2017 10:45 am
Thank you Stuart. That's exactly what I needed. All ordered now.
Rob.
1964 E-Type 3.8 FHC
1969 Mini Cooper
1973 Austin 1300GT
