Workshop manual
Can anyone advise the best place to obtain a comprehensive workshop manual to suit an XK8 4.0 in build December 1998 , registered March 1999. I need to replace the power latch hydraulic pipes ( 1 burst ! ) and it looks a mare of a job . I've no doubt I'll need a manual for many other jobs over the coming years !
Re: Workshop manual
Hi - I've nothing to offer in terms of a ROM but I will observe that the hydraulic fluid congealing is a known problem with these cars. I'm wondering if that is the cause of the burst pipes?
I would recommend changing the fluid and flushing the pipes through while you've got it all apart!
Re: Workshop manual
Thanks David , however , the fluid was anything but congealed ! Rather more like gnats p ! The air temp was particularly hot at the time ! just need to know the best way to remove the pipe( s ) .
Re: Workshop manual
This link should answer most of your queries http://www.jagrepair.com/RoofHoseReplacement.htm
The host site for that article is www.jagrepair.com and is an invaluable source of technical information for many modern Jaguars.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
Re: Workshop manual
Thanks for that info . I thought it was going to be a nightmare ! The only good thing was that , my roof was already in the lowered position !
How did you attach the old pipes to the new , tape or double male connectors ?
Regards ,
Mike .
Regards ,
Mike .
Tonyinmeva
Re: Workshop manual
Hi all, I would also like to get hold of a workshop manual for my 1998 XK8 coupe, I am about to change my tensioners , I have read all the post,s here and you tube so have a good idea , but having it in front of me whilst doing the job would be nice . a download or paperback.
Any ideas
thanks Tony..in Cornwall
Any ideas
Re: Workshop manual
Try this previous response to a similar query (viewtopic.php?f=62&t=6657#p31703). Mike.
Re: Workshop manual
This is my most favourite document when it comes to V6 and V8 Jag engines. Worth book marking or downloading for future reference.
http://www.google.co.uk/url?sa=t&rct=j& ... NwdrKUf4YQ
