Relay clicking when power off
ihopland
Postby ihopland » Wed Jun 07, 2017 2:09 pm
I have an Jaguar xj40 1992 model. When I turn power off the s/lamp power relay and aux/side relay start clicking and the bumper lights starts blinking at the same speed as the relays. Anyone who have an idea of what can be wrong ?
Tanks
Inge H
pimgmx
Re: Relay clicking when power off
Postby pimgmx » Wed Jun 07, 2017 5:24 pm
Inge,
My first suspect would be the so-called lighting logic module: this is a printed circuit board built into the front top side of the dash.
That unit governs the exterior lights as well as the hazard lights.
A couple of phillips screws below the dash panel keep things into place, remove those and you should have good access.
Look for corroded/dirty connectors as well as dry solder joints on the circuit board.
This is what the thing looks like:
NB: connectors on yours might be slightly different, XJ40s had many electronics changes over the years...
the ex-daily: 93 3.2 Sovereign http://bit.ly/14GTNrq
the minter: 93 4.0 Insignia http://bit.ly/1iGrmsU
the hooligan: 95 XJR http://bit.ly/1cW11DN
the GT: 89 5.3 XJ-S http://bit.ly/1WQGpC5
pimgmx
Postby pimgmx » Wed Jun 07, 2017 5:26 pm
Inge,
My first suspect would be the so-called lighting logic module: this is a printed circuit board built into the LH front top side of the dash.
ihopland
Postby ihopland » Sun Jun 25, 2017 7:04 pm
Thanks for advice. I am still working with the problems. When the problems are solved I will inform you.
