Hesitation when cold.
jazzman20014
Postby jazzman20014 » Wed Jun 07, 2017 11:09 am
Hello,
After a little advice on a 2001 3.0 S-type. Back at the start of the year the breather pipe at the back of the engine was replaced as it had collapsed. At the same time the Lambda sensors were also replaced - long story short after getting the incorrect and faulty sensors finally sorted out, generally the car is going great. With the notable exception of when it's cold, immediately after start up when pulling away there is a hesitation that will suddenly clear with either a little surge or when the throttle is closed, then it's absolutely fine for the rest of the journey.
This repeats again when cold, but not if you restart hot.
Does anyone have any experience of such a fault?
Many thanks.
Re: Hesitation when cold.
Postby J44EAG » Wed Jun 07, 2017 12:19 pm
I would suggest you clean the Mass Air Flow sensor mounted on the outlet tube on the air cleaner box lid. Two Torx screws secure it to the tube. Clean using spray switch or carb cleaner. Dirt could have built up on the bulb and hot wire. It should be silver clean rather than black with dirt. Do not touch with hard tools. Check the air filter on the dirty side of the filter. It might be chock full of muck and not have been changed for years.
Secondly remove the air trunking to the throttle body. Clean out the throttle throat and throttle plate with spray carb cleaner and soft cloth. Wear nitrile examination gloves. It is a dirty job. Ensure the plate and throat are spotlessly clean and that the plate closes with a good snap.
Tighten all air trunking pipe clips and see where you are at that point. Tighten all inlet manifold bolts. We can go from there if there are issues still present.
jazzman20014
Postby jazzman20014 » Fri Jun 09, 2017 8:34 am
Hi Mike,
Thank you for your reply, finally managed to get a chance (between downpours) to do this last night. Overall everything looked very clean to start with and I did have an issue removing the MAF sensor, as both screw heads sheered off and there is no sign of it wanting to move out the intake, probably for the best. So taking the top of the air box it was easy enough to clean the MAF and the screws are a job for the weekend :?
After giving the intake and throttle body a good clean and checking the butterfly is moving as you described, it seemed much better taking it out last night and again this morning. Will keep an eye on it over the next few days and see if it stays that way.
Thanks for your help!
Matt
