Tensioner Noise
PeterDavisX300
Tensioner Noise
Postby PeterDavisX300 » Mon May 15, 2017 8:32 pm
Hello.
My X300 has for a wee while made the short rumble when starting from 'semi-warm' due to the usual tensioner wear. I notice that most of the parts are no-longer available from JLR, is there a fix? I guess it must be something to do with the 'O'-rings or the non-return-valve. Is there anyone with a new one out there? The blades all looked in good-enough condition when I had the head off. I've done all the usual re-sets etc of the tensioner.
Any comments welcome.
Peter
1984 Mercedes 450SL Rag-Top
naki
Re: Tensioner Noise
Postby naki » Sat May 20, 2017 10:38 pm
I would say its worth trying a new O-Ring on the upper tensioner since they are pence (assuming you do the work yourself).
I have used tensioners if you need one. PM me for details.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
PeterDavisX300
Re: Tensioner Noise
Postby PeterDavisX300 » Sun May 21, 2017 10:45 pm
Thanks for the reply Naki. I was going to replace what I could on the existing tensioner to see if that would stop the rumble. Aye, I do all my own work.
Thanks.
Peter
