A frame gutter rubbers
Loneranger
Postby Loneranger » Tue May 09, 2017 7:06 pm
Like many an XK8 convertible owner my car has suffered from the aluminium in the gutter trim rubber corroding and bubbling.
I came across a company on eBay called seal-extrusions. They were offering RUBBER U CHANNELS EDGE TRIM SEAL BLACK 10 MM 5 MM FLEXIBLE
This appeared to match up to the dimensions of the original rubbers so I thought I would order 2 metres at a cost of £5.40 with free p and p
At that price I thought it was worth the investment, if they did not work it was only a small amount of money.
The rubber seal arrived in a couple of days. I removed the gutter trim the removed the original rubber, fitted the new seal with a slight overlap and when in place cut to size.
The result I am rather pleased with. I have attached 3 photos. One shows the original rubber with the corrosion, two shows in progress and three shows the completed job.
xk8 3.jpeg (14.51KiB)Viewed 2775 times
xk8 2.jpeg (9.11KiB)Viewed 2775 times
xk8 1.jpeg (13.02KiB)Viewed 2775 times
1998 XK8 Convertible in Sherwood Green Metallic Ivory Leather- Weekend sanity motor 1500 miles pa
2014 Mercedes-Benz C220cdi silver weekday warrior 50k pa
Re: A frame gutter rubbers
Postby mike020150 » Wed May 10, 2017 9:25 am
Well done. Sadly, this problem afflicts more XK8s than those without it. The more options to improve matters, the better it will be for us all. Mike.
