Brake pipes
wombat
Brake pipes
Postby wombat » Sat Apr 01, 2017 5:26 pm
Hi all,
The last MOT had an advisory for a rusty rear brake pipe. I plan to replace using Cunifer pipe, so before I get it jacked up does anybody know if the brake pipe connectors are metric or imperial and the size?
I will try and remember to take some photos as I go. I also have the 2 rear shocks to replace as well.
I will also take the opportunity to replace the brake fluid as I suspect this is original as well! DOT 4 is the recommended I believe.
Garry
1999 XK8 Coupe
2009 LR D3
Both make me smile :D
Re: Brake pipes
Postby Brakebuster » Sat Apr 01, 2017 6:08 pm
before you do , quite a few of the replacement parts are still available from jaguar and reasonable prices
i recently had to change a rear brake feed pipe at the front of the car for a fellow member on his 2004 XK8 , and it was only £17 i think for the pre formed correct pipe,
all fittings will be metric , and yes, Dot 4 fluid will be fine
