Remote not locking/unlocking car
charlier6790
Postby charlier6790 » Sat Mar 25, 2017 11:52 am
The remote on my 2003 3-litre sport has just stopped working and I am having to lock/unlock the car with the key. I have changed the battery in the remote and tried the spare remote but no joy. Any advice about next steps would be much appreciated. Thanks. Charlie.
GordonJ
Re: Remote not locking/unlocking car
Postby GordonJ » Sat Mar 25, 2017 12:00 pm
Charlie,
this might sound stupid, but did you clean the contacts in the remote when you changed the battery. I had the same problem on my wife's S Type and it wasn't the battery at all it was the contacts needing cleaned. A light rub with a pencil rubber cured the problem.
Gordon
XJ6 X350 Sovereign
Previous Jaguars.
XJ8 Sovereign in Seafrost
S Type in Red
charlier6790
Postby charlier6790 » Sat Mar 25, 2017 12:41 pm
Hi Gordon, many thanks - it was certainly worth a try - but unfortunately no luck. Any other thoughts? I've also cleaned-up the key slot in the ignition barrel but no joy with that either. Thanks again. Charlie
GordonJ
Postby GordonJ » Sat Mar 25, 2017 1:34 pm
Hi Charlie,
unfortunately I don't have any other thoughts on the matter, all I can think of is the age old question which I am sure you will see a lot of on the forum " is your car battery fully charged". Other than that I am sure someone with more experience will come along shortly and answer your question. Have you looked for other threads on the forum on the same subject?
Gordon
XJ6 X350 Sovereign
Previous Jaguars.
S Type in Red
