Front seat belt slow or jammed X308
Moderators:robv12, DavidEm
freezo1962
Postby freezo1962 » Sat Feb 25, 2017 5:53 pm
Hi I have to say a big thank you to the person who posted the attached information (see link).
http://www.inclusivechoice.com/Temp/Jaguar/page2.html
It has saved me from buying a new seat belt, I did not even have to remove the top clip and bracket, as i only removed the bottom two fir tree clips and carefully lift the trim forward and could see the belt was twisted, so I moved the twist up to the top and out through the top adjustable buckle where i could easily remove the twist, the belt now returns all the way back and is as good as new. Pictures are really clear.
hope this will also help other club members with belts that currently do not fully return.
Mark Freeman
