tire choices
I will be changing my 2007 XK tires very soon as there wearing out quite quickly (i do have have a heavy right foot :w00t:) I currently have dunlop sports max and was wondering what other tires people use
Re: tire choices
The only cure for a heavy right foot is a wedge under the accelerator pedal! Your rear tyres will last longer after fitment.
None of the major branded tyres recommended for the XK range is sold as a particularly low wear option. They are all about grip. However, that is not a bad thing with a minimum of 300bhp to control. If you use the search facility you will see there have been a few previous conversations about members' views on tyre brands. Personally, I lean towards Dunlops largely because, in my experience, they appear to have slightly better traction than others, like Pirellis, when conditions are cool. However given similar prices, any tyre choice is only ever a compromise between noise, grip, handling and wear. No tyre is perfect. It's more a question of the order in which you choose to rank these qualities. Mike.
Re: tire choices
Another vote for Dunlops over Pirellis: quieter and less wear-prone.
I use(d) them on several of my XJs and they hold really well, and have lots of grip in the wet.
Depending on driving style you could also consider Michelin Pilot Sports: good rubber for the more spirited driver with excellent grip on wet roads. The latest generation - Pilot Sport 4 - has done great last summer, driving through the Alps in our (non-Jag) Roadster!
the ex-daily: 93 3.2 Sovereign http://bit.ly/14GTNrq
the minter: 93 4.0 Insignia http://bit.ly/1iGrmsU
the hooligan: 95 XJR http://bit.ly/1cW11DN
the GT: 89 5.3 XJ-S http://bit.ly/1WQGpC5
Re: tire choices
Dunlops have been my tyre of choice for a long time now. Much lower road noise, better grip and, for me anyway, decent all round wear.
If you are tempted by other non Jaguar specified brands it may be worth sounding out your insurer as to where you would stand if the worst should happen.
Jim
Jim
