Radius Arm fitting
Mr.Ian
Radius Arm fitting
Postby Mr.Ian » Fri Jul 13, 2007 9:27 pm
Hi all, rear radius arms!
What i'm after is the relation of the large bush to the 'top hat' mount when the arm is being re-fitted back to the car.
Reason for asking is during my rebuild of my XJS I had nothing to work from to get any measurements as the whole area was a big botch, and I need to sort where the new 'top hat' mounts sit on the chassis.
I've got the across the car dimensions it's just when you go to fit the radius arm back on the mount (at the jacking point) does it pull the arm forward or push it rearward slightly, or is it straight on?
Thanks people.
Mr.Ian
Radius Arm fitting
Postby Mr.Ian » Mon Jul 16, 2007 9:18 pm
Have found the exact measurements now in the parts cat.
1978 XJ-S V12 Auto - Under Restoration
