Brakes - no servo ?
Azzura
Brakes - no servo ?
Postby Azzura » Sun Nov 06, 2016 10:17 pm
No power brakes!
1969 Series 2 E type; a car I purchased at an auction had no power brakes, the jubilee clips on quite a number of the vacuum hoses had been loosened, having made sure all the joints were tight still no power brakes. Were do I start trouble shooting to trace where the problem is. The system does look complex! Brake fluid levels are all OK and the pedal is not spongy.
steve_m
Re: Brakes - no servo ?
Postby steve_m » Sun Nov 06, 2016 11:34 pm
I think that you are in the wrong forum, you should be in the E Type one, this is for X Types.
Good luck anyway!
