Amongst the papers handed over to me when I bought my XJS was the service booklet for this car. I thought it woukd be nice to reunite the car and booklet.
Anyone know where L101LWR might be?
Matthew
Seeking the owner of XJS 4.0 Reg L101LWR
Matthew
1993 XJS 6.0 V12
1993 XJS 6.0 V12
Re: Seeking the owner of XJS 4.0 Reg L101LWR
No MOT since failure in 2012 and on SORN, not looking good
Reason(s) for failure
Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Power steering pipe(s) or hose(s) leaking (2.3.3b)
Power steering component(s) leaking (2.3.3b)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Windscreen has damage to an area in excess of a 10mm circle within zone 'A' (8.3.1a)
Offside Windscreen washer provides insufficient washer liquid (8.2.3)
Offside Front Tie bar/rod rubber bush deteriorated resulting in excessive movement (2.4.G.2)
Nearside rear parking brake recording little or no effort (3.7.B.6a)
Offside rear parking brake recording little or no effort (3.7.B.6a)
Parking brake: efficiency below requirements (3.7.B.7)
Advisory notice item(s)
Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
Gearbox mounting defective
