Dash board lights
ammo
Dash board lights
Postby ammo » Sat Aug 20, 2016 1:33 pm
Hi I am new to the club just over a year ago I got an 2002 xk8r just after warranty ran out it keeps coming up on the dash as check rear lights /overdrive not available, I have checked the lights and they still work even with this fault ,would anyone now how to cure this fault. many thanks
Loneranger
Re: Dash board lights
Postby Loneranger » Sat Aug 20, 2016 4:26 pm
Often if you disconnect the battery both terminals then hold them together for ten seconds it is enough to reset faulty warning lights. You will need to reset your windows after battery disconnect. Send window down hold until you hear click then continue to hold for ten seconds then send back up. If the battery disconnect does not work find yourself a good local specialist who will be able to fault check.
1998 XK8 Convertible in Sherwood Green Metallic Ivory Leather- Weekend sanity motor 1500 miles pa
2014 Mercedes-Benz C220cdi silver weekday warrior 50k pa
PTR200Jag
Postby PTR200Jag » Sat Aug 20, 2016 4:36 pm
This probably won't be the only time you get a dashboard light and message!
I would go with battery disconnect as suggested but buy yourself a code reader. I- soft do suitable ones.
I have had a raft of lights and messages and this was the best new " tool" I have bought for some time !!
Just a thought on the problem, check the brake light switch connection too.
XK8 MY2002
