Manual Gearbox 5 speed oil recommendation
xjscharlie
Postby xjscharlie » Sun May 15, 2016 11:32 am
Hello Folks,
Can anyone advise a recommended oil for the 5 speed box. The manual just gives a Jag spec. Tks.
poprivet
Re: Manual Gearbox 5 speed oil recommendation
Postby poprivet » Sun May 15, 2016 5:36 pm
If you have the spec, look it up at Opie Oils, I'm sure they will have alternatives that are suitable.
xjscharlie
Postby xjscharlie » Mon May 16, 2016 7:00 pm
Hello,
Thanx for reply but Opie is only recommending engine oils. If you request gearbox oil it gives a drop down menu which only options engine oil, no gear oil option.. Never mind..I was hopeful tha someone with a bit of experience would be able to answer as its a basic question.. Charlie.
