Hi All,
This is probably an old question to most but can someone help me? I recently took my '93 4.0 XJS facelift to have the gas recharged, but the mechanic took the usual sharp intake of breath and told me the valves need to be replaced and he'd source some new ones and get back to me....he didn't. Now the sun is out I want to start using the car again ! Can anybody tell me what the parts are actually called so I can order them There are two, and I'm not at all technically minded but they look like tyre valves. What do I need to replace them? and is there anything else I should be wary of about what I think should be a fairly straight forward job?
Air Con gas Recharge
Hi I believe you are talking about schraeder valves? they are used to fit gauges too when recharging. regards Kels
Hi Chris, welcome.
Im really sorry to hear you are having problems getting your A/C sorted. Its not that its a technical minefield, but it *is* a problem finding sympathetic technicians who both understand the needs of older cars and are confident enough to complete a job to give a guarantee that the repairs will work for more then a short while.
These technicians do exist, but you may have to look hard to find one locally.
Your mechanic is referring to the two schrader valves. If the dust caps have been left off for some time they could well be the point of leakage, more likely though the gas will have leaked out somewhere else. The escape needs to be pinpointed first, else a re-charge will only go the same route.
The more I hear about xj-s owners receiving poor service with A/C matters makes me increasingly mad. Maybe I need to get my certification fast-tracked and get these critters cooled!
Pop
Pop
chris000000
Thanks Pop and Kelsham, at least I know what these are called now!The mechanic claims the ones on my car are now illegal, is that so and if they are, do you know what specific valves I need to replace the old ones.
thanks for your help
Chris
Chris
Your car would have originally had R12 refrigerant, the replacement for this in newer cars is now R134a. To prevent anyone mixing the two, the connections changed.
Pop
Pop
I would just like to clarify that R134a is NOT an acceptable substitute in an R12 system. There are a couple of correct gases to use, one of these is RS-24.
I do hope your garage is not simply saying that your valves need replacing because they are the old R12 type. It is quite possible to get adaptors (like we have). Your valves are definitely NOT illegal!!
I have found so-called 'air conditioning specialists' ignorant of the proper replacement gas. So I would say make sure you know what he wants to change the valves for, and what gas he is going to put in. If he's going to replace R12 gas with R134a, tell him no deal!
If you're anywhere near nottingham I'm sure we could take a look at your AC for you.
CLEAN old '87 XJ-S 3.6 manual (for sale!)
If no-one buys it soon, its going on classic insurance!
'96 XJR manual (the green monster)
Quite correct Jon, I was assuming that Chris was having a full conversion done, not a 'top up'.
I have edited my last post for clarity.
Pop
Pop
Just thought I ought point out that RS-24 is widely beleived to be R134a/butane (98%/2%) and it's about a tenner a kilo
XJ-S 3.6 230k miles +
