No Power from Radio
sheldon1
No Power from Radio
Postby sheldon1 » Fri May 06, 2016 1:42 pm
My replacement s type 3.0 SE , the radio has failed to work since I bought it. I have checked the fuse No2 in the drivers well , but the fuse is intact. Had the fuse tested and it seems no power is coming from the radio. ?
Any thoughts?
thanks
Re: No Power from Radio
Postby J44EAG » Fri May 06, 2016 6:32 pm
Power comes from the battery, not the radio!
Do you have the radio display illuminate to allow the security code to be entered? I recall three or so attempts are allowed before the radio locks up after which dealer intervention may be needed to allow the radio to function again.
Consult the drivers handbook for further advice.
sheldon1
Postby sheldon1 » Fri May 06, 2016 7:06 pm
Thanks Mike
