X Type 3.0L V6 2001 AWD rear drivers side window stuck open.
xjscharlie
Postby xjscharlie » Tue May 03, 2016 8:08 pm
Hello folks,
the rear drivers side window has stayed down. All others working correctly. On using the rear drivers window switch there's a click indicating that it is powered up so should'nt be a fuse. Can it be reset? HELP. Charlie.
Bellajag
Re: X Type 3.0L V6 2001 AWD rear drivers side window stuck o
Postby Bellajag » Mon May 16, 2016 9:59 pm
The only way I know to reset them is to pull out the fuses and then refit them again. Then try the window but you may have to hold the switch in the up position.
