Trim removal
prsgue40
Trim removal
Postby prsgue40 » Wed Mar 23, 2016 4:44 pm
Hi all Any one know how to remove the trim panel below the steering wheel. I need to get at the brake light switches without breaking my back or the trim panel!!! Thanks Bernie
prsgue40
Re: Trim removal
Postby prsgue40 » Wed Apr 13, 2016 12:27 pm
Hi For information.Its held on by one push in plastic plug (a little like the under bonnet engine cover) and spring clips. Remove the plug and pull the panel straight back towards the seat. I bent one spring clip but managed to reform it. Bernie
prsgue40
Re: Trim removal
Postby prsgue40 » Wed Apr 13, 2016 12:38 pm
Hi Still on trim but this time on refixing cloth to interior trim. I had cloth detaching from the two trim panels each side of the screen. It can be re-glued with spray glue a used by carpet fitters. A two second squirt on both surfaces and its done. Take care though as its contact adhesive.Bernie
