Memory seat problem
kevst183
Memory seat problem
Postby kevst183 » Sun Feb 28, 2016 5:54 pm
Hi, my drivers seat sometimes moves back when I turn off the engine and sometimes it doesn't. When I get in and start up it doesn't move back. I've tried re-memorising the positions but it doesn't usually work and have to do it myself.
Anybody know if the problem is the seat module or the memory switch in the door?? All the motors work using the seat buttons and the headrest, seat back and base all move as they should, it's just the memory.
Kevin
Topaz x300 Sovereign 4 litre in Sunny Southend on Sea
robv12
Re: Memory seat problem
Postby robv12 » Mon Feb 29, 2016 2:21 pm
you don't say what car you have??, but this is usually a case of failed/failing potentiometers in the seat, I had a similar issue with a 1997 X300 recently, the seat worked perfectly except the memory function, we swapped out the module and switch pack, reprogrammed the key fobs and car to no avail, so a used seat was sourced and stripped to use the used motors and potentiometers, not easy, time consuming, but job done
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
kevst183
Postby kevst183 » Mon Feb 29, 2016 7:10 pm
Thanks for the info, I think I will just put up with mine!!! :shock:
