Lower Spoiler Wanted
As in the subject, Lower Spoiler/Chin required.
Re: Lower Spoiler Wanted
R Edgar,
For what car? Do you mean the undertray fitted to late big-bumper cars or the small black spoiler fitted to earlier cars?
You might also find it helpful to put your car details in your signature and your location in your profile.
R Edgar,
Thank you Paul, obviously an XJS, hence the request being on this Model Forum. The spoiler as in the add, hence the reason for not requesting an undertray. I thought I had listed my car and location in my Profile. I will check and update if necessary.
Thanx again Paul
If you have a look on http://www.jaguarclassicparts.com/uk you may be able to identify the part you need, there are many variations on models and years.
If you go to the user control page you can add car and location details in a signature, lots of help on here once we know what we are looking for.
If a pre-facelift, I imagine it is No 1 in the diagram? Part number BEC13168
Hope this helps a little.
Spot-on Pop.If you have a look on http://www.jaguarclassicparts.com/uk you may be able to identify the part you need, there are many variations on models and years.
Thank you.
Uploaded an image I'll look at my profile again.
R. Edgar,
I think we assumed it was an XJS because your were posting in the XJS section of the Bulletin Board, but you hadn't said what year, pre-facelift or facelift etc.
If it's BEC 13168 that you're after, then it's still available from Jaguar. With JEC discount from your dealer, you should be able to get it at £200 all in.
OOPS! Sorry Paul,I did not mean to be impertinent, I, wrongly, thought facelift & pre would be the same part.
Lots to learn.
It seems that the required part is, at least, as you suggested but not yet being in possession of the car I will have to check to make sure that I do not need other parts.
Thank you.
Roger
Lots to learn.
Thank you.
Roger
Roger,
Absolutely no offence taken! Post back if you need other parts. There are also couple of reputable XJS breakers that we can put you in touch with if it's second-hand parts that you're considering.
Thank you again Paul.Roger,
I would be interested in the details of the 'breakers' you guys use.
Roger
Roger,
Here's a few to start:
- Graham Hallett at Grublogger 07771 508614
- Andy Harvey at Just XJS 07940 998189
- Clarkes Jaguar of Sussex 01435 836800
