Burst Mouldings Rear Window XKR 2002
clivesaunders
Postby clivesaunders » Tue Dec 22, 2015 1:54 pm
Hello to all
Both of my rear Qtr window Trims have burst.
The shaped metallic grey moulding on which the rain seal sits.
Internal grey substance has expanded.... can the problem be addressed or is it 'replace'
the seal & mouldings.
If so I assume the rubber seal also...a job for the body shop ! ?
What are these parts called and part No's ? could not identify in parts list
Best Regards
Clive XKR Peasemore
Re: Burst Mouldings Rear Window XKR 2002
Postby mike020150 » Wed Dec 23, 2015 11:42 am
Assuming we are talking about a coupe, the trims/rubbers are referred to as 1/4 glass finishers and used to carry the part numbers GJA2231AF (LH) and GJA2230AF (RH). As mentioned recently in the magazine, these trims should now be available again to order from Jaguar dealers. They have always been expensive so brace yourself if you decide to renew them. Alternatively, you or a body shop might be able to refurbish your old trims depending how bad they are. Mike.
