65 S type 3.8 Pas , Stopped Charging , where to start pls ?
silverfox
Postby silverfox » Mon Dec 14, 2015 7:03 pm
Only just happened , Fan belt tight , advise appreciated , thanks Russ
Martec
Re: 65 S type 3.8 Pas , Stopped Charging , where to start pl
Postby Martec » Mon Dec 14, 2015 7:49 pm
Is it an alternator or dynamo?
How do you know its not charging?
silverfox
Postby silverfox » Mon Dec 14, 2015 10:42 pm
looks like a Dynamo with the PAS bolted to the back ? .
oldtimer
Postby oldtimer » Mon Dec 14, 2015 10:46 pm
With the engine stationary measure the Battery voltage with a volt meter and record the reading. Start the engine ,run at 1500rpm and take another reading and record the reading.
The second reading should be higher than the first reading - tell us the results of your findings and we will go from there.
silverfox
Postby silverfox » Mon Jan 11, 2016 1:01 am
Thank u for your help guys , to update u the Battery wasn't being charged so ive removed the Dynamo and the regulator and sent them away for a recon { £200 } , i wait their return , Russ
