external temperature
On my 2001 X308, the external temperature gauge
lacks accuracy (it indicates about 3 centigrades more than actual temperature. This is not a major concern, since this is more for fun than anything else. I suspect that this lack of accuracy is due to a sensor covered with mud, acting as an insulator from the cold. - But I may be wrong. Anyway, does anyone know where this sensor is located ?
Re: external temperature
phirou,
If it's the same as my old x308, I believe it's located at the front end of the engine bay, either on that x-member or on the front edge of the bonnet. Somewhere around there, from memory! Apols if I'm misleading you!
