IRS Strip Down and Rebuild
Re: IRS Strip Down and Rebuild
Postby davidr » Sun Jan 15, 2017 4:40 pm
So now the exhaust over-axle pipe and the back boxes are off and so are the radius arms.
Next I detached the prop shaft. Just a case of removing 4 nuts and bolts from the flanges as below.
The propshaft was the pulled to one side and rested carefully on the heat shield as below
Next I undid the brake union and plugged the pipe. I did this at the body end as the replacement unit has a stainless braided hose. You could detach it at the cage and clamp the hose off if you're going to use the same hose but I thought that an opportunity wasted.
The handbrake cable was removed as below.
So there it is - only things left holding it on are the vee mounts and the speedo pickup is still attached.
We held the exhaust centre sections up by putting some square section between them and the ramp arms as below.
Postby davidr » Sun Jan 15, 2017 4:49 pm
Next comes the real point of doing this on a 2 post ramp. A table was placed under the car and the ramp lowered until the IRS was on the table. Then the vee mount bolts were removed and the car can be lifted up away from it. Much easier than trying to do it by yourself with the car up on axle stands and trying to balance it on a trolley jack as you lower it. I could see myself getting hurt that way!
Here's the point of separation. The car is going up and the IRS staying on the table.
We raised the car just enough to get easy access to take the speedo sensor out of the back of the diff. (Earlier cars will not have this - the speedo is cable driven from the gearbox).
Then it was up, up an away!
Postby davidr » Sun Jan 15, 2017 4:52 pm
The old IRS was looking OK I thought. The paintwork on the frame has stood up well and it will clean up nicely.
Postby davidr » Sun Jan 15, 2017 5:13 pm
Time taken to get that unit out was just under 2 1/2 hours once the car was on the ramp.
After filling the diff with oil and moving a few minor parts between them (and a good lunch!) it was time to put the new one in.
Here it is sat on a transmission jack ready to go in. The reason we used the transmission jack and not the table is because the jack is on wheels and so is easier to position precisely under the car to get the vee mounts to line up with the chassis rails.
The car was moved down so speedo pickup could be bolted on. There are shims to space the sensor correctly to the crown wheel. As this was the original unit going back in and I hadn't changed any shims I was happy to put it straight back in.
Then the car is fully lowered onto the unit and the vee mount bolts pushed through. It takes a bit of wiggling and levering to get them in but by flexing the rubber in the vee mounts a bit they will go in.
Everything else then just went back together in the way that we'd taken it apart.
The only hard bit is getting the large radius arm bushes over the mount on the body. The key is to twist the rubber bush so the inner sleeve goes on the mount straight. Trying to get it close enough and pulling it up with the bolt will just result in the thread stripping. We used the transmission jack to hold it as below.
Bleeding the brakes is just a case of not letting the accumulator pump run for too long so it doesn't overheat. We first let gravity pull the fluid through and then operated the brake pedal without the ignition on so the pump wasn't running. That way we got most of the air out before we finally bled the last with the pump running. We got a nice firm pedal although we did have to nip up a couple of unions to stop small leaks.
Postby davidr » Sun Jan 15, 2017 5:18 pm
So here's a couple of pictures of the unit in the car
Postby davidr » Sun Jan 15, 2017 5:20 pm
...................and finally, why take out a perfectly presentable IRS?
Here's a picture of the sump plug from the removed unit.
Postby Brakebuster » Sun Jan 15, 2017 5:20 pm
fantastic
well done David , looks amazing, and no doubt sounds much better
Postby J44EAG » Sun Jan 15, 2017 7:51 pm
A perfect job, David. Proper good.
It would have been quite a challenge to get that unit in by yourself. Glad you played safe and went down to Hollygrove. I remember how heavy those diffs are and it wouldn`t have been nice to have had a fitment accident. In any case four hands or more make the work go so much better and it is always fun bouncing off the guys you are working with. I should think the job would have been almost impossible on the ground even with two decent trolley jacks.
I hope you were well chuffed when you drove home. A pint here on the bar for you if you are in my area.
Postby davidr » Mon Jan 16, 2017 8:46 am
Thanks Vince and Mike,
I did drive it home with a sense of dread! You tend to listen out for any little noise or anything that feels even slightly strange. Happily all was well and I was able to relax and enjoy the vast improvement.
I'm glad I did go to Hollygrove. It would have taken me at least twice as long on my own in my workshop and it's always helpful to have a few lads around to both help and advise.
Next will be to retrieve the IRS that I took out from Hollygrove, strip it down and do a post mortem on the diff.
My guess is that the nose bearing has disintegrated at the very least and it's quite likely that the crown wheel and pinion are damaged. It'll be interesting to find out.
David
Postby Brakebuster » Mon Jan 16, 2017 9:39 am
when installing my new rear anti roll bar a few days ago , i noted that my prop shaft to diff bolts were no longer ' tight ' not loose , but two of the four could have done with half a turn
i believe its a known issue that the drive shaft bolts can become loose over time and need to be checked , as this can manifest its self in an initial knock or click when accelerating , and also when putting into reverse ,
when i replaced my original prop many years ago with a new one, i noted that the original mounting holes had gone oval and would never function correctly again no matter how tight the nuts and bolts were , there was also wear to the bolts ,
just a maintenance check point for the future ,
Postby davidr » Mon Jan 16, 2017 7:13 pm
Yes. Will's parting comment was "check the prop shaft bolts in a couple of weeks" so I will keep an eye on them.
Phil 18
Postby Phil 18 » Tue Jan 17, 2017 8:18 pm
Good tidy work David, Well done.
Phil
Phil
4.2 XK8 2004
rknowles74
Postby rknowles74 » Tue Feb 14, 2017 4:51 pm
Stunning write up David - you make everything so easily understandable.
A while back you commented on the need to check the camber once the IRS was installed in the car, and maybe adjust the shims.
Have you done this yet? I would love to see your description and pictures of this task, and hearing how you calculate the shims needed.
My diff needs rebuilding, and once that has been done (I wont be doing it myself) I will need to go through the process you have been through. The part I cant get my head around is figuring out the camber adjustment shims.
Richard
Postby davidr » Tue Feb 14, 2017 9:59 pm
Richard - thanks for your comments. my hope was to leave a reference for people who were going to do this. If they want to tackle it themselves then good luck. If they didn't want to or don't have the facilities then at least they'll understand the process.
I've not yet got around to checking the camber but I'll do it like this.
First check that the tyres are up to the recommended pressure. This will mean adding a few pounds for me as I run them lower than Jaguar say they should be for comfort - I'm not going to be taking her all the way up to 150mph after all!!
Then I'll check the ride height. This should be measured at the bottom of the tie plate below the inner fulcrum shaft. It should be 190.6mm +\- 6.4mm.
The manual says you should put in special tie down links to set the ride height appropriately but the same can be achieved by putting weight in the boot.
I have a small simple camber measuring tool that I will use to check.
The camber should be 0.75 +\- 0.25 degree negative.
In other words, the top of the tyre should be angled in slightly between 0.5 and 1.0 degree. I think it's also good practice to have them within 0.25 degree of each other.
The genius of the IRS is that the drive shaft also acts as the upper wishbone link. By altering the effective length of the driveshaft using shims the driveshaft either pulls in or pushes out the top of the wheel as shims are added or taken away. Add shims to increase camber - take them out to decrease.
Each shim (about 0.5mm thick I think) is worth 0.25 of a degree.
It's a pain because the driveshaft has to be unbolted to put in/extract shims so not a 5 minute job!
When I do get around to it I'll share the process here.
However, my camber tool is not very sophisticated so to be sure I will take the car to Julian at Micheldever Tyres who understands how to set up the IRS very well and he has much more clever kit than me for checking geometry of all 4 wheels.
Postby davidr » Tue Feb 14, 2017 10:11 pm
This is the type of camber gauge - not terribly sophisticated (or expensive!)
This is the driveshaft. Part number 1 is the shim. This goes between the driveshaft flange and the brake disc that it bolts on to.
