Rebuilding XJ-S suspension... Rear First.
SimonR
Postby SimonR » Wed May 10, 2023 6:11 pm
I had another shift at it today, with help from my dad. It was nice to have some company in the workshop for a change!
We've got everything back together, except the outer fulcrum at the hubs and also the damper / tie down bracket shaft as I couldn't find my notes about how the large washers went back on. I'd welcome some insight about that as it's not at all clear in the workshop manuals.
Today's video round-up: https://youtu.be/Sd9Pyr2Tonc
Here's the unit back together:
Here's how we've se up those two shafts with the washers - How did we do?!
Tie down bracket end (rear):
Front end:
I'm sure there should be a large washer on both sides of the hub/wishbone fulcrum!
SimonR
Re: Rebuilding XJ-S suspension... Rear First.
Postby SimonR » Tue May 16, 2023 11:34 pm
I've been scratching my head for the past few days about why the outer fulcrums were too long and why the shims / washers didn't fit as per my notes when taking it apart.
I don't mind admitting that I'd made a rather basic error and got the outer fulcrum shafts and the shock absorber mounting shafts on the wishbone mixed up. After I'd checked the pictures I'd taken of the suspension prior to dismantling, and also reasoned that the smaller diameter threaded ends probably wouldn't take 131 Nm torque the pfennig dropped. I live and learn,,,,,
With the error rectified, I got on with re-fitting the assembly to the car - here's the scene in the workshop this evening:
During this whole process I've had a method in mind for getting the IRS back into the car and I was pleased to find out that it worked. I was concerned that having the car at quite an angle may make it tricky to line the Vee mounts up, but I found that I could lift the IRS up on my motorcycle jack, get the front-most bolt in place and then use this to pivot the unit around on the jack to enable me to get the other bolts in. The only problem I had was that the new Vee mounts are a very tight fit and it took me over an hour to get the bolts right through them
It's just a case of re-connecting everything now, and recovering a set of spare exhaust tips in my stash of spare parts. I've completely failed to remove the originals from the old back boxes but they're a bit tatty anyway so I'm happy to fit a pair of good condition replacements.
SimonR
Postby SimonR » Fri May 19, 2023 10:26 pm
It's nearly finished!'
I had a Jaguar-based morning which I'll post about in the General section, however, this afternoon was set aside to work on the XJ-S.
Today's video roundup: https://youtu.be/maHUzq56EI0
I torqued up the vee-mount bolts, ARB bolts, wheel hub nuts, attached the radius arms and safety straps, and then greased all the grease points. Next was the exhaust pipe - firstly the 3 nut and bolt / olive joints immediately in front of the suspension assembly, but I realised that I couldn't get it lined up until I put the back boxes in place, so I quickly attached them and then adjusted their positions until everything was free of other parts and looked correct.
There isn't a whole lot left to do:
-Adjust the handbrake cable to give a little more length to it will re-attach to the callipers,
-Bleed the brakes,
-Replace one radius arm bolt and lockwire it
-Grease hub bearings ( see below)
-Fit road wheels
-Pass MoT.
It'll be a few days now as I'm waiting for the radius arm bolt to arrive.
Quick question - is it really correct to pump a load of grease into this hole in the hub carrier?
Postby ptjs1 » Fri May 19, 2023 11:01 pm
Great efforts Simon!
QQ, shouldn't some of the rear setup be tightened and torqued only when the car is on its wheels and weight-loaded? I can't remember from when I last did mine, but something makes me think that you should have certain areas under car weight before tightening them?
Just a thought...
Postby davidr » Sat May 20, 2023 10:36 am
Paul is right. For example, if you tighten the small radius arm bolts with the wheels hanging then the bush will be twisted when you put the weight of the car back on the suspension. Best to tighten it on the ground to avoid the risk of tearing the rubber bush.
SimonR
Postby SimonR » Sat May 20, 2023 2:12 pm
Thanks gents - I'll consult the big green book and exercise some common sense before I put it back on its wheels.
I'm just off out to the workshop now, with my other half and three year old, to play a family game of 'down... hold', 'up again', 'down' etc., whilst I follow Paul's instructions from when I replaced the brake fluid last year.
SimonR
Postby SimonR » Mon May 22, 2023 11:17 pm
Good news - with the handbrake adjustment issue resolved by cutting a very small slit in the sill carpet, directly under the seatbelt rail bolt, I managed to get the handbrake cable in situ and adjusted it to engage in a more positive way than it ever has. This was the final hurdle preventing me from getting the car back down onto its wheels.
Thanks to Paul and David for mentioning that some of the IRS bolts need to be torqued with the car's weight on the wheels - I read both the big green book and the Haynes manual and then slackened /retorqued the ARB mounting bolts/nuts and radius arm bolts once the car was back on the ground.
Then came the moment to start it up for the first time in 7 months:
https://youtu.be/S7oKujk6s2k
The poor old thing was very dusty after all that time static in the workshop and when I do the front suspension next winter I'll make sure that I cover it up from the start.
My new Karcher pressure washer with car shampoo/foam wand, in conjunction with the ceramic coating that I'd had done soon had it looking its best again:
With everything now complete, except for one radius arm bolt that I'm still waiting for, I booked the car in for MoT on the 2nd June. After that it'll be off to get the alloy wheels refurbished and new tyres fitted. I can already report that the brakes are a LOT sharper than they were.
Thanks once more for all the help, suggestions and direction that I've been given throughout this project - I literally couldn't have done it without your input!
SimonR
Postby SimonR » Fri Jun 02, 2023 10:27 pm
Just to finish up this thread - it was a good day today. I took the XJ-S out for its first drive since I started this work: all of about 300 yards to the MoT test station... where it passed with no advisories, and compliments from the tester about all the work that had been done.
I celebrated by taking it to a classic car meet-up in a nearby village - where my handiwork was inspected!
