IRS Strip Down and Rebuild
oldtimer
Re: IRS Strip Down and Rebuild
Postby oldtimer » Mon Jul 18, 2016 10:39 pm
Those bits have cleaned up a treat, well done.
Postby davidr » Sun Aug 07, 2016 11:51 am
OK - time for the next instalment!
Enough dismantling now and the rebuild begins. First will be he hub bearings.
I started with driving in the outer races for the hub bearings. My preferred way of doing this is to grind down the outside of an old one and use that as a mandrel to tap it in with a hammer. You can see my ground down old race on top in the photo above. Alternatively I could do it in the press I suppose.
Here's the race part way in
Keep tapping it in until it seats and the tone of the hammer changes. 2 things to remember. First this should be an interference fit so it can't spin and secondly its important to drive it in square. If its not a tight interference fit then I'm afraid your hub carrier is scrap.
Here's the outer race fully seated.
Next was to press the outer bearing onto the hub. I made sure the hub was clean and there were no burrs or rough edges. A put a little grease on too. We have discussed on here various things such as heating the bearing or freezing the hub. I didn't find that necessary and the pressure applied by the press was minimal. Its important to pay attention here! These are tapered roller bearings and you have to make sure you put them on the right way round!
Next job was to press the ABS ring back on. As mentioned before, care is needed here as its cast iron and therefore brittle. Very little pressure was needed and they pressed on easily. If they put up a fight then don't force them too much! Try freezing the hub and heating the ring.
And here's the hub assembly all together and greased
At this point it's important not to forget to put the oil seal into the outer bearing on the hub carrier. I have to confess, I did forget first time and had to drive the hub back out again! D'oh!!
This is now ready to put the hub and hub carrier together.
Postby ptjs1 » Sun Aug 07, 2016 12:18 pm
David,
Great pics and description, as usual! Well done!
Postby davidr » Sun Aug 07, 2016 12:20 pm
The seal is tapped in carefully using a soft faced hammer. This one is nylon.
I put the outer race in for the inner bearing as described above and then inserted the hub into the carrier, put the inner bearing in place and set it up to press the inner taper roller bearing onto the hub.
And here is the bearing pressed home and the seal in place
Note how the end of the hub within the bearing sits a bit lower than the top of the bearing. If left like this then there would be significant pre-load on the bearing (ie squeezing the 2 taper bearings together) when its all done up. The ideal is that there is between 2thou and 6thou of end float (ie there is a small amount of room for the bearings to expand as they heat up).
To achieve this end float, a spacer is inserted as shown below. The spacer is pointed out by the pencil.
This extends the end of the hub and makes it slightly proud of the top of the bearing and gives the required end float. Spacers are available in varying sizes.
I've taken the view that as I've replaced the existing spacers and bearings are made to pretty tight tolerances then its probably OK. I may have a fit of perfectionism later and measure it all properly!
Postby davidr » Sun Aug 07, 2016 12:35 pm
As you'll have guessed, the previous posts were me catching up on the things I've been up to over the past couple of weeks. Now we're reasonably up to date here's what I was doing yesterday.
I've finally managed to get around to collecting my bits from Ferndown Finishing. Here they are
Lovely to get shiny new-looking parts back isn't it?
The eagle-eyed amongst you (yes Oldtimer - you!) will notice a few extra bits in here as I chucked all sorts in as it doesn't really affect the price. (I paid £40 to have this lot and a few more bits done).
A happy hour was then spent checking it all over, cleaning up threads and putting the bits back in their original bags to make sure that all was present and correct. Happy to say it was!
Postby davidr » Sun Aug 07, 2016 1:02 pm
Here's my diff with the backplate refitted. A bit of silicone to seal it and then the shiny bolts and level plug were put back in and tightened up.
I've put an old speedo sensor in just to seal the hole.
Now I'm going to mount the brake discs and calipers.
There are spacers that go between the disc and the output shaft. Their job is to adjust the distance relative to the caliper so that its centred.
The caliper bolts through and its important that the lugs are clean, free of burrs and have no paint on them that can wear away and make things go loose.
This one needs the wire brush!
Brake caliper lugs cleaned off.
Brake disc is mounted - here I've used some thick washers and the old metalloc nuts to pull the disc in tight.
I've not yet checked the run-out but I will.
The calipers are mounted and then a feeler gauge used to check that the disc is reasonably central in the caliper. Its not necessarily possible to get it spot on as its +/- the width of a shim.
I'm now ready for the handbrake assembly to be installed but I'll have to build them up first.
I haven't lock-wired the caliper bolts yet as I want to check the run-out and make sure I'm happy the discs are centred before everything is tightened up and lock-wired.
Postby J44EAG » Sun Aug 07, 2016 4:34 pm
Very nice, David.
Postby Brakebuster » Sun Aug 07, 2016 8:23 pm
looking good there David
and looking forward to catching up with you later this month
oldtimer
Postby oldtimer » Sun Aug 07, 2016 9:46 pm
Did you get all those bits from Waitrose ?
Postby davidr » Sun Aug 07, 2016 9:54 pm
Of course! From their "Essentials" range!
XJR-S
Postby XJR-S » Fri Aug 12, 2016 11:06 pm
Really stunning work. I want to do this! One day I shall.
Postby davidr » Sun Aug 14, 2016 10:43 am
Yesterday's first task was to reassemble the handbrake calipers. Here's what I started with
Like a jigsaw puzzle it pays to have some idea of what the finished picture looks like!
First step was to examine all of the parts and check for any damage or burrs and that the blocks in the arm move freely.
This is the end that the cable goes into and needs to be free to move.
This block has the friction spring clipped to it and the bolt goes through it via the toothed adjuster nut. It needs to be free to move or the pads will not self-adjust freely.
The pawl and spring are fitted over the posts in the main arm.
(please note that all parts were fitted here without grease to make the photos clearer. I took it apart again after this procedure and re-assembled it all with plenty of grease!)
Next assemble the toothed adjuster nut and the friction spring below
And push it on to clip over the block in the arm to engage the pawl. It will be held in place later when the bolt goes through it
Postby davidr » Sun Aug 14, 2016 11:11 am
Next is to assemble the inner pad carrier which consists of the carrier, anchor pin, pad and pad mounting pin and washer and nut.
Below are the pad carrier and anchor pin. The pin goes through the carrier and the return spring is attached to it on the other side.
The bolt goes through the carrier and the pad slots into it and is bolted on with a shake proof washer as below and the return spring is attached to the anchor pin
Remember to put the inner protection cover in place before assembling the carrier in the arm and clipping the other end of the return spring over the post in the arm.
Next was to put the pad on the outer carrier (and yes the pad is upside down before the eagle eyed make comment!) and put the bolt through it and screw it into the adjuster nut.
Next put the outer cover on and the insert the hinge pin and put a split pin through it to secure.
Insert and tighten the screw that pulls the inner and outer protective covers together.
The last thing is to a split pin that fixes the screw so the adjuster nut can pull the pads together to compensate for wear. Leave the split pin so you can still pull it out for now to allow easy adjustment later. Once the pads are faced up then the split pin can be put in permanently.
Postby davidr » Sun Aug 14, 2016 9:31 pm
As it says on all good shampoo bottles "rinse and repeat".
The other side is just the same but a mirror image.
And this is what you get
These are now ready to be mounted.
But first I wanted to check the run-out on the brake discs before I tightened the caliper bolts off and lock wired them.
Postby J44EAG » Sun Aug 14, 2016 9:44 pm
Fiddly little blighters?
Now I know why I put my old V12 XJS out to Jagcare when I had a handbrake problem with it!
When finished, you will probably have one of the finest rear cage units fitted to any XJS. A massive job and not for the faint hearted.
