Jeff
Sill corrosion
Well I did the job today, sill covers off and a little bit of rust at the jacking points the rest of the sills were perfect. So wire brushed and treated with Granville Rust Remover then Waxoiled. I bought a pack of clips from my local dealership, about twenty quid and guess what, none of the original clips broke, sods law or what. But worth every penny for piece of mind.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Sill corrosion
Hang out the flags folks, Jeff1154 has had the sills off at last. I've just re-read this thread and noticed that you threatened to do this job over a year ago - on my birthday no less !
I'm pleased for you' in that you have found no nasty's. Well done and as you say peace of mind.
Now, just a little bit more info. I recently had the front wing liners out along with the front plastic bumper and under panels. Why, you might ask - well the screen washer performance was poor so I deduced that it must be the pump. Well it wasn't, I eventually discovered that the near side bonnet hinge had guillotined half way through the feed hose.
So what has this to do with sills ? Whilst the wing liner was out I noticed that there is access into the sill end. This allowed my long probe to pass the length of the sill on the inner side of the strengthening rib which divides the sill cavity into two . Another coating of Waxoil just to make sure
Perhaps a job for the future
Oldtimer
PS. Good luck with your new motor
Oldtimer
Re: Sill corrosion
That's interesting Oldtimer, this would allow access with a Drainage type Camera Probe to see condition of the inside before taking the Plastic Covers off.
Doug.
Doug.
S Type Forum Moderator
Re: Sill corrosion
Thanks Oldtimer for your applause (if that's the the right word) I have mentioned in the past somewhere on the forum, that my car was fitted with mud flaps all round from new. I think that this has gone a long way over the years in protecting the front part of the sills.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: Sill corrosion
Hi Doug,
Never thought of that but yes a camera might be just the job - have recently had one shoved up were the sun don't shine - should have taken the car and asked them to have a shooft in me sills while they were at it !!
Oldtimer
PS. We used to call it a shoofty scope
Oldtimer
Re: Sill corrosion
Cheap enough on ebay. Plug direct into a laptop or stand alone versions available.
Re: Sill corrosion
Mike,
Would that save me going back to the hospital ?
Re: Sill corrosion
No Oldtimer you are in the NHS system now so you can expect the 'pleasure' every 3-4 years!!
PS hands slap accepted for moving off topic!
