Dodgy bodywork on the XF
Moderator:cawthrm
dolphinfreindly
Is the blue called kyanite?
Re: Dodgy bodywork on the XF
If you take the three letter paint code to Halfords, they should be able to mix a can of aerosol paint for you. I`ve found the colour matches excellent and after cutting back, they blend in perfectly with the existing paint.
ianoliver57
Try the parts dept of your local Jaguar dealers. If you give them the paint code (from the door pillar) they will supply touchup paint of an exact match. If its a small repair (mine was) then touchup paint may be all you need. Easier to use than spray paint!!
Ian .
Ian .
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
2021 XE R Dynamic P250 S
Previously
2004 S Type
2010 XF 3L petrol
2014 XF R-Sport
2010 XKR 5L
2011 XF S
2017 F Type 340
2019 XJ 3L V6
I get my spray can paint mixed at Halfords for about £16 a can. Just take your paint code (usually found on a plate in the front passenger door shut on the A pillar....three letters) to Halfords and they will do a special mix for you whilst you wait. In my experience the colour match has been excellent once the dry dust new paint edges have been flatted with P1200 or P1500 W&D paper. Polishing up with a rubbing compound has the job gleaming and well blended into the existing paintwork.
