Postby ptjs1 » Tue Nov 28, 2006 3:18 pm
Gordon,
Assuming that you've decided to fix yours and not buy DH Dove's "spare" car....
I'm now assuming from your update that you have a relatively early facelift car (91/92 - VIN pre198334), in which case effectively the master cylinder is an integral part of the servo-hydraulic booster which also contains the ABS valve block.
The whole of this assembley is indeed £1600 + VAT (befoe any discount that you can negotiate).
Within the valve block there are three pairs of solenoid valves. One pair controls both rear wheel brakes. The front wheel brakes each have a pair of valves. A reduction in brake pressure on one wheel could well be the result of one pair of valves being partially closed.
However, the valves only come into play when the ABS side of the system comes into play. In other words, under normal braking with no locking of a wheel being sensed, the valves should be fully open. When a wheel starts to lock, the wheel sensor sends a signal to the ECM which in turns controls the relative solenoid valve to adjust the brake pressure on that wheel circuit (A locking of either rear wheel will cause the pressure across both rear wheels to be reduced)
So if this is the cause of the problem then one of the valves has stuck in the partially closed position even under normal braking, or else a wheel sensor is sending a false signal and causing the ABS system to kick in unnnecessarily.
It seems to me that one way to clarify whether the problem is being caused by the wheel sensor or the valve block would be to shut off the ABS system and try the brakes and see if the problem is still there. If the problem goes away then that would seem to indicate that the problem is not in the valve block but is perhaps in the wheel sensor or ECM.
I don't know what would be the best way to do this and wouldn't want to mislead you from a safety perspective. Perhaps there is a fuse that controls the ABS or maybe you could just pull the ECM plug from the servo-booster unit. I'm sure your mechanic will know the best (and safest way to try this)
Hopefully this might help you to find the problem in the cheapest and quickest way. I'd hate to think that you could end up changing the whole actuator unit if the problem is somewhere else like a wheel sensor.
Hope that helps again.
Sheepy - I'm aware we're focusing a lot on Gordon's issue. Are you any clearer on the way forward for yourself, seeing as you started this thread?
