Standard exhaust too quiet
smoggy1965
Re: Standard exhaust too quiet
Postby smoggy1965 » Sat Sep 25, 2010 10:37 am
I too wanted to improve the sound quality, so for £100 the local exhaust garage's stainless steel fabrication man cut the exhaust off in front of the back boxes and replaced with a through :lol: pipe, fixing the origonal exhaust caps on the end. The noise is just right and yet another good reason to keep the hood down.
Smoggy1965
Rotherham, England, UK
1999 XK8 Cabrio, Meteorite Silver
Clasic Oatmeal and Antalope Interior
Aftermarket ipod & Bluetooth Conversion
Back Box through pipes
HID conversion + LED sidelamps
Adamesh windbraker
Adhesive front numberplate
[img][/img]
Postby mike020150 » Tue Sep 28, 2010 11:08 am
Excellent value! Mike.
RMA37
Postby RMA37 » Fri Jan 11, 2019 5:11 pm
This is an old thread but the topic I would imagine is still current. I too want to increase the sound slightly, this is the quietest V8 I've had (1997 XK8 Convertible). So I went along to my local Powerflo Exhaust dealer and he suggested 3 options.
1. Replace rear boxes with straight through pipes.
2. Replace rear boxes with new pipes with smaller boxes.
3. Replace the mid boxes with straight through pipes.
These options will give different sounds, and without actually trying them, I wouldn't know what I would end up with. Does anyone on here have experience with Powerflo exhausts, and has anyone done any of those options to their car with any make of exhaust?
Thank you
Postby mike020150 » Fri Jan 11, 2019 5:36 pm
Sadly, you can't beat listening to a modified car to hear if the result is the one you want and can live with. Hence, go to a regional meeting and ask to hear members' modified cars or attend a Modern XK Forum meeting to do the same.
I ran a 4.2 litre convertible without the rear silencers and enjoyed the (cost effective) experience of increased V8 woofle. Others haven't. Apart from noise volume, the rear boxes are also there to damp down a natural V8 resonance which occurs at around 70mph in top gear. Without the silencers, if the slight resonance bothers you, the noisier exhaust will tend to enforce cruising speeds of around 5mph either side of the resonance frequency. It's all a matter of taste. Mike.
RMA37
Postby RMA37 » Fri Jan 11, 2019 5:44 pm
Thanks Mike, I'll ask around. I would be interested to hear from anyone who has used Powerflow. Their exhausts are made on site and welded on, not a kit. Unfortunately that doesn't make refitting the old one very easy if the sound isn't acceptable.
